littleman
| posted on 12/3/12 at 01:33 PM |
Waterpump issues?
Had my ZX9r Tiger out yesterday and it keeps overheating. Weird thing is that if I am driving at high revs accelerating hard through the gears then
it will stay at a reasonable temp but as soon as I slow to a constant 4k ish rpm then it heats up quickly to around 100-110, a down shift and a boot
full of power and the temperature drops instantly to a more reasonable 90.
I replaced the water pump last year (albeit with a used item) but there is no coolant weeping from the drain hole and I disconnected one of the rad
pipes and cranked the car and coolant spilled out. Any ideas what to try next??
maccmike
| posted on 12/3/12 at 01:51 PM |
temp sender
temp guage
stat switch
cooling fan
FuryRebuild
| posted on 12/3/12 at 03:26 PM |
Do you have bleed pips running to the header tank from the highest points? Could be some trapped air that gets pushed around under high revs?
Also, when is your fan set to come on? If the loud-pedal sorts it, maybe it's down to air-flow over the rad?
littleman
| posted on 12/3/12 at 03:36 PM |
Nope, no bleed pips to the header tank, the connection on the header tank has been blanked off with a bolt, do you think its worth fitting a t-piece
in the pipe-work just before the top of the radiator (highest point) and running a pipe to the header tank? or even getting a piece of tubing welded
to the top of the radiator and connecting to the header tank from there?
I have the fan running constantly with the ignition.
40inches
| posted on 12/3/12 at 06:03 PM |
Shouldn't be necessary to have fan running all the time.
I have plumbed mine in using this chart
works perfectly, fan cuts in and out, and temp steady at around 95.
blakep82
| posted on 12/3/12 at 06:27 PM |
YES! especially from the thermostat and radiator!
________________________
jacko
| posted on 12/3/12 at 07:07 PM |
Front grill ? too small holes i know two people that has had this problem both was sorted by removing the grill
Jacko
40inches
| posted on 12/3/12 at 09:22 PM |
That may be the problem, a header tank is part of a sealed system and carries the "rad" cap,and the rad doesn't have a cap.
So if your tank isn't in use, it will be an expansion bottle and your rad will have a cap, if this is the case, then you may be losing coolant
when the system vents, and draws in air as it cools. Just a thought.
Expansion tank
littleman
| posted on 13/3/12 at 09:23 AM |
Thanks for all your replies guys.
I'm going to plumb an air bleed in to the expansion tank and also take the front grill off to see if that makes a difference.
Question for '40 inches' - how did you put the bleed in to the thermostat housing? I'm pretty sure my housing doesnt have a
connection for it, did you just put a t-piece in the pipework?
40inches
| posted on 13/3/12 at 11:07 AM |
There is a connection on the housing for the hose, can't get to it to take a photo at the moment, but if you look
here at part no:92005A (stat housing) you can see the fitting for the hose, a banjo fitting 92005B. It's
tucked well under the carbs and may have been capped off for some reason.
The part is directly above the down arrow on the fiche, just clip in that area to enlarge it.
[Edited on 13-3-12 by 40inches]
littleman
| posted on 13/3/12 at 11:27 AM |
Thats perfect mate, it definitely has been capped off, I remember seeing it when I took the thermostat out to test it worked properly. Thanks a lot
for your help, I'll let you know how I get on!
littleman
| posted on 14/5/12 at 12:11 PM |
So i eventually got the weather to test this out, my thermostat didnt have an air bleed so i fitted one back to the header tank and it works a treat!
Had it out on Saturday and it never went above 85 degrees.
Thanks for your help everyone.
