Author: Subject: CAM PROBLEMS
RMK
posted on 25/8/04 at 05:12 PM Reply With Quote
CAM PROBLEMS
has anyone had any problems fitting an high lift cam to a pinto head.fitted two cams and one lobe has been warn away within 350 miles. any suggestions
Jon Ison
posted on 25/8/04 at 05:41 PM Reply With Quote
loads of cam lube, accurate follower settings, and run it above 2-2.5k revs for a while on 1st start up,
pinto cam set up is crude and agricultural to say the least...........
its a while since i fitted one, some one will prob give you better up to date details.
mookaloid
posted on 25/8/04 at 06:58 PM Reply With Quote
As Jon says..
and are you saying that the same lobe went on two cams? if so I would have a very close look at the spray bar and the hole for the oil for that lobe.
posted on 25/8/04 at 08:26 PM Reply With Quote
Did you change the followers at the same time?? adjust valve clearances correctly??change the spray bar?. if it was the same lobe worn on both cams it may be worth checking the valve to piston clearance? may be possible to check through plug hole with a piece of solder pushed under valve. hope this helps, Rusty
david walker
posted on 25/8/04 at 09:23 PM Reply With Quote
Valves won't hit pistons on a Pinto.
Are springs coil binding? Quickest way to wear a cam out if they are!
[Edited on 25/8/04 by david walker]
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
RMK
posted on 26/8/04 at 03:09 PM Reply With Quote
cam problems
fitted new spray bar,new followers and there is no spring binding and still took the same lobe of.kent cams sent me a reprofieled cam and some followers . with cam fitted everything looks ok.
