onenastyviper
posted on 25/3/12 at 04:23 PM |
rear/mid-engine mounting - thought exercise
Afternoon All,
What would your opinion be against mounting a bike engine longitudinally but connect directly (or through a cushion drive) to the rear differential to
form a sort of short mid-engine layout?
Just a thought exercise, so let the comments or suggestions fly!
imp paul
| posted on 25/3/12 at 04:33 PM |
its been done lots of times just have a look at the spire gtr should help you see how to do it
Ivan
| posted on 25/3/12 at 04:37 PM |
Don't see any problem with the idea - some others do just that, the "short propshaft" will take the longitudinal space taken by the
clutch, flywheel and part of gearbox in a conventional transaxle.
But don't really see the advantage as compared with a chain drive transverse layout as you can get very similar location of the engine centre of
gravity either way and the chain drive diff might be lighter.
[Edited on 25/3/12 by Ivan]
zilspeed
| posted on 25/3/12 at 04:39 PM |
That's how the Turner LMP did it.
I've also seen an MK GT done like that too.
First thought is that you have to keep all of the diff, which is a weighty bit of kit.
Second thought, there's a load of drag in a fully built up diff compared to a chain and sprocket setup.
On the plus side, mounting the engine longitudinally pushes a major mass ( the driver) away from the rear wheels.
The means he's either nearer the front wheels or you've lengthened the wheelbase.
Whatever the case, there's a strong chance you've given the front wheels a bit more to do and the rears a bit less, so it may influence
ultimate grip levels.
Not sure it would be enough to offset the extra drag of the final drive.
I would say that longitudinal is of course the way that all car engined racing cars are ( apart from one which use a FWD package in the back, but
that's done for reasons of cost.)
It's also the case that pretty much every bike engined mid engined racing car I've ever seen had a transverse engine.
I have seen a longitudinally mound bike engine driving straight into a a diff, but that was a Clan Crusader which must maintian that orientation for
the class it ran in.
For a long time, that car had catastrophic understeer until they rectified it all by engineering in some more front end bite.
Make of all of the above what you will.
I can see your reasons though, just not sure I would have the courage to make what is a pretty bold manouvre and flies in the face of what the rest of
the world seems to have accepted as standard practice.
onenastyviper
| posted on 25/3/12 at 04:40 PM |
Thanks, I can start looking. I didn't know if it had been used before.
Just did a quick forum search and found a few threads discussing it. It helps when you use the right key words!
onenastyviper
| posted on 26/3/12 at 04:15 PM |
Thanks for the info.
