Author: Subject: Hazard switch wiring?
Gti6boy
posted on 1/4/12 at 08:04 PM Reply With Quote
Hi, I have a bec Mk Indy which has indicators running through a 3 pin led flasher unit
I was trying to add a hazard switch for iva but was having a bit of trouble
What's the easiest way to add this switch in to the system?
Nick
Simon
posted on 1/4/12 at 08:42 PM Reply With Quote
Do a search - there is a wiring diagram on here somewhere.
Someone may be along who can remember where it is
Simon
[Edited on 1/4/12 by Simon]
Gti6boy
posted on 1/4/12 at 09:00 PM Reply With Quote
I did look first, will try again
russbost
posted on 1/4/12 at 09:05 PM Reply With Quote
Basically in the simplest system, all you need to do is connect 3 terminals together - 2 x flasher bulb connectors & the flashing feed from the flasher unit - it's the system I use on the Furore, I use the bike flasher unit & the Toyota hazard switch, but I only use 3 terminals on the hazard switch rather than the complex system Toyota use!!!
Gti6boy
posted on 1/4/12 at 09:15 PM Reply With Quote
Sorry I'm a proper newb with car electrics!
I need to connect to one of the cables going to an indicator on one side, and another cable to the other side? Also to the centre pin on the flasher relay?
The Venom Project
posted on 1/4/12 at 10:26 PM Reply With Quote
Job Done
Just buy this kit, simples...
VW Trike hazard warning lights for MOT, full kit. | eBay
It's not that i'm lazy, it's that I just don't care.....
Gti6boy
posted on 2/4/12 at 07:09 AM Reply With Quote
