MikeFellows
| posted on 5/5/12 at 01:44 AM |
Hayabusa Speed Sensor - Help
How do people setup the speed sensor on the hayabusa
I dont even know where to begin to be honest, because its impossible to use the original bracket as it has to be removed to fit the sprocket adapter,
also what do i use for a pickup, do I need to place magnets on the top of the sprocket adapter, if so where abouts?
sorry, but its pretty much the last thing i need to have the busa electrics done
any photos would be hugely appreciated
cosmick
| posted on 5/5/12 at 08:21 AM |
Hi Mike,
I have placed the speed sensor almost in the original area and used the 4 bolt heads on the propshaft adapter to drive the sensor. You do not need any
magnets. the sensor has a magnet in it and it will pick up a metal object that goes past it if it is close enough. So, it is very easy and neat to fit
as you will not need to extend the harness wires, being in the same position as standard. I have put a photo in my archives if you would care to have
a look.
[Edited on 5/5/12 by cosmick]
If it can't be fixed with a hammer then its probably an electrical problem.
MikeFellows
| posted on 5/5/12 at 02:35 PM |
your a superstar
thank you
cosmick
| posted on 5/5/12 at 04:29 PM |
No problem. Are you going to Stoneleigh? i will be and with my car if you are interested in looking at it.
