Macca
| posted on 18/9/02 at 12:23 PM |
SVA
I can't narrow it down to one specific post but I'm led to believe that testing a bec offers up more problems than a cec. I am/was planning to build
with the donors engine etc. get through the test and then convert to the bike motor.Am I doing the right thing? What are the problems testing the
bec?
Help!
Col.
ChrisGamlin
| posted on 18/9/02 at 12:52 PM |
Hi
First post on here, but I'm sure a couple of you will recognise me from the BEC Yahoo list
Theres no specific problem with getting a bike engine through SVA, like any other engine, if it is newer than 1995 then it needs a cat in the exhaust
to meet emissions, but you could go for a 1993/94 blade or something similar and bypass that.
Noise is the only other thing that may catch you out, though its easy enough to get it through without resorting to OTT silencers.
The only real advantage of going with the donor engine/box for SVA / registration is that you've got a fighting chance of getting an age related
plate rather than a Q, unless you build your car from totally new parts apart from the bike engine/box in which case you could possibly get a new
"52" plate.
I would seriously think about all the things that you'd need to change if you do an engine transplant from the donor to a BEC afterwards, as there's
a lot that would need changing, for example:
New engine mounting in chassis
New prop needed & new mounts in tunnel
Wiring will need redoing to splice in bike ECu and ignition system etc.
Instruments etc replaced or rewired (need 12+krpm rev counter etc, and donor speedo wont have a pickup on the bike gearbox)
New/modified cooling system
New exhaust and different sized cutouts in side panel (possibly need to re-panel the side?)
Modify fuel delivery with different fuel pump etc, also possibly require new tank and pipes if going for injected bike engine.
May even find you need to change springs etc to take into account 100kg weight loss in engine bay.
When I started building mine, I initially planned to do what you are doing, but I decided it was far too much hassle and went the direct route with
bike engine to start with.
Chris
Jon Ison
| posted on 18/9/02 at 05:25 PM |
Welcome Chris......
Jon..... AKA stagsparty...
chrisg
| posted on 18/9/02 at 06:39 PM |
AKA smelly arsed bastard!
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Jasper
| posted on 18/9/02 at 07:28 PM |
Jon AKA - Wot roundabout???
Good to see u here Chris...
paulf
| posted on 18/9/02 at 09:07 PM |
I am have a 96 blade engine that i obtained before i started building. However i am putting in a crossflow and planning to sell it after a little use
and put any profits towards the extra parts for the bike engine installation such as the instruments and exhaust.
I have fitted basic instumentation and am planing on using a race type manifold that exits through the bonnet side as on the locost race cars. I will
need a different bonnet anyway to suit the bike engine and can then cut the hole for the bike exhaust in the side panel.I am thinking of using a bike
exhaust box with the crossflow so will then just need the manifold.
Paul.
quote: I can't narrow it down to one specific post but I'm led to believe that testing a bec offers up more problems than a cec. I am/was planning
to build with the donors engine etc. get through the test and then convert to the bike motor.Am I doing the right thing? What are the problems testing
the bec?
Help!
Col.
ChrisGamlin
| posted on 19/9/02 at 11:06 AM |
Thanks for the welcomes guys, and Jasper, thanks for the post regarding the chopped sump, I passed on your comments to John.
Are either of you down at Llandow this weekend?
Chris
Jasper
| posted on 19/9/02 at 02:42 PM |
'fraid not, gotta work....have fun....
ChrisGamlin
| posted on 19/9/02 at 02:47 PM |
It will be tricky, but I'll try
Chris
