Poll: Engine mountings [View Results]
Yes,i use allot of rubber 1
Yes,i use allot of rubber 1 nick205
Yes,i use allot of rubber 1 nick205 scotlad
Yes,i use allot of rubber 1 nick205 scotlad Mark18
Yes,i use allot of rubber 1 nick205 scotlad Mark18 phelpsa
Yes,i use allot of rubber 1 nick205 scotlad Mark18 phelpsa Peteff
Author: Subject: Engine mountings
tks
posted on 1/9/04 at 02:57 PM Reply With Quote
Engine mountings
I want to know if the engine mountings have rubbers or not, soow did you use the engine as a stressed member or not.
silex
posted on 1/9/04 at 07:15 PM Reply With Quote
I normally rigid mount, but unstressed.
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
Jasper
posted on 1/9/04 at 07:24 PM Reply With Quote
No rubber - unstressed
BTW - the text on your pole makes no sense, so didn't vote.
[Edited on 1/9/04 by Jasper]
Mk-Ninja
posted on 1/9/04 at 07:35 PM Reply With Quote
Jasper. Press the right pedal a bit harder, that will stress it
I'm sure I've got one, just don't know where I've put it
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 1/9/04 at 08:59 PM Reply With Quote
hmmm that vote didn't quite work the way id hoped! mines rigid mount!
tadltd
posted on 1/9/04 at 09:20 PM Reply With Quote
Used the exact same mounts as those on the bike - so solid at the 'rear' and rubber at the front.
A lot of work goes into designing those mounts, which is why it's a good idea to carry them over into your build. Stressing an engine in a place it wasn't designed to be could lead to BIG problems...
Best Regards,
Steve.
www.turnerautosport.com
Mark18
posted on 2/9/04 at 04:57 PM Reply With Quote
I voted for "Yes,i use allot of rubber 1 nick205 scotlad" and I stand by it.
Mark
EDIT: I hardmounted my 'blade by the way.
[Edited on 2/9/04 by Mark18]
phelpsa
posted on 4/9/04 at 04:15 PM Reply With Quote
Everytime someone votes its added to the list.
Adam
posted on 6/9/04 at 12:44 AM Reply With Quote
Rigid Mounted
No rubber - thanks!
Aloupol
posted on 7/9/04 at 12:10 PM Reply With Quote
Surprising to read "no rubber, unstressed"...
Is there something I missed? If it's rigid mounted the stress comes into it, except if the frame is times more rigid than the engine, but I think it's not the rule..
Think twice before applying stress, if it's different (or more important) as in the bike it could lead to heavy mechanical problems..
loafersmate
posted on 7/9/04 at 03:24 PM Reply With Quote
The engine is almost suspended in the chassis on two top mounts with a connection to the lower chassis at the rear of the engine (if it's a blade).The rear top mount on the early blade is rubber lined like a metalastic bush (not sure of the later blade or other makes). I think most people are calling it unstressed as it's not designed as a load bearing structure - that's what the chassis is for
Ben
posted on 7/9/04 at 05:58 PM Reply With Quote
Don't need a rubber as I had a vasectomy. I occasionally get stressed but I am solid mounting my engine. I am in the process of designing a cradle for it as we speak. It moved us to the bottom of the poll and still reads 0%, how strange.
