posted on 15/5/12 at 07:57 PM |
WTD: Disco 2 front prop
CHEAP front prop of a disco 2 please anyone?
One of this type...
dray13dad
posted on 15/5/12 at 08:02 PM |
have you tried Britparts yet? do loads of stuff for all landrovers
tomgregory2000
posted on 15/5/12 at 08:26 PM |
Good luck trying to find a cheap one, everybody wants them for the double carden joint which is what I guess you want it for
posted on 15/5/12 at 09:20 PM |
Aye, your damn right, there's a knackered one on the bay and he wants £85 for it! The rest are over a ton 1/2.. then the cardon rebuild kit is
about £66..
Want a cheapo second hand one cause I need to get it lengthened, theres no off the shelf parts to fit the length I need.
mark chandler
posted on 15/5/12 at 09:42 PM |
Do you have to use one of these? I have a couple of P38 prop shafts, front and back in my garage if of any use. They just have standard UJ's
both ends.
posted on 15/5/12 at 10:14 PM |
I've got 3 standard props, just thinking of upgrading them for the lift I have on the truck.
mark chandler
posted on 15/5/12 at 10:34 PM |
I really would not worry.
When I raced a 80" with the engine pushed back I used a classic range rover rear prop as it has very deep yokes and chopped it into a very short
length, on full droop with coil springs and extended shocks it was at horrible angles so relocated the A frame brack on the diff to point the nose up
a little.
The front prop was never a worry as plenty long enough although had to grind the flats on the yokes as they used to rub at the axle end.
Regards Mark
posted on 16/5/12 at 09:27 AM |
Cheers, front prop is going to be 30 1/2" nice easy gradient down to the axle although the output from the transfer case points up a little bit.
Rear is 19" with the brake drum pointing down slightly and I haven't pinned the A frame yet so I have the nose of the rear diff pointing
straight at the tranny output.
Think I'll get away with standard yokes?
BobM
posted on 16/5/12 at 10:27 AM |
Try Austen (MK9R on here), his Dad does Landie transmissions.
Not very Locost but very BEC
posted on 16/5/12 at 08:10 PM |
And after much searching I can come to conclusion the double cardon ned flange is too big for my classis range rover.. DOH!
Landrover Discover II TD5 Front propshaft with double cardan joint. (greasable)
TVB 000100
Length: 605mm (closed)
Front Flange Config:
Spigot: 60mm
PCD: 80mm
Hole Config: 61mm x 51mm
Rear Flange Config:
Spigot: 65mm
PCD: 95mm
Hole Config: 67mm x 67mm
Looks like I'm going to have to make my own ones....
