Author: Subject: R1 Clutch cable
madrallysport
posted on 4/6/12 at 03:03 PM Reply With Quote
R1 Clutch cable
I'm at the stage off needing to fit my clutch cable to the car, i looked at this a long time ago and couldnt figure it, but now it needs done, have you any pics of how you mounted the cable to the chassis off the car etc and the cable used. Its a carbed engine, cant remeber the engine code of the top of my head.
[Edited on 4/6/12 by madrallysport]
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
renetom
posted on 4/6/12 at 05:43 PM Reply With Quote
R1 clutch cable
Hi
We used a Capri clutch cable on ours, & made a bracket bolted to front lower engine mount
See sketch in our archive.
The clutch is a bit like an on & off switch so I devised a way of giving more throw by making a longer lever
Will be fitting it soon (also in our archive).
Good luck
René
