tcr
| posted on 12/6/12 at 12:08 PM |
marked reverse switch
just ordered one of these eBay - The UK's Online Marketplace going to get the cobbler to engrave an R onto it to
use as a reverse switch has anyone else done this and will it pass the IVA ?
[Edited on 12/6/12 by tcr]
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
tilly819
| posted on 12/6/12 at 01:20 PM |
I did that, the ally bit on the front comes off with some picking, then i just letter stamped REV into it and stuck it back on,
was fine for IVA main thing is to interlock the switch with the neutral light so that you can not activate reverse while in a forward gear.
hope this helps
tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
tcr
| posted on 12/6/12 at 01:26 PM |
hope this helps
tilly
is that a requirement for the iva or just something you did for precaution ?
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
40inches
| posted on 12/6/12 at 02:08 PM |
I think that linking the reverse with the neutral light is a must, accidentally switching the reverse on when moving forward
wouldn't be a good thing! I have a main switch and a small joystick + have also linked it with the brake light switch, applying the brakes
switches the reverse off.
For marking the switch I used Letraset.
  Reverse Switch Panel
BobM
| posted on 12/6/12 at 03:07 PM |
It's not a requirement. Only requirements I can see are that the mechanism will propel the vehicle backwards and the control must be reachable
from the driver's seat.
Not very Locost but very BEC
tcr
| posted on 12/6/12 at 04:29 PM |
i thought as much but wasn't 100% sure thanks
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
tcr
| posted on 19/6/12 at 01:51 PM |
here's one i made earlier
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
tcr
| posted on 2/7/12 at 07:07 PM |
just ordered a universal brake light switch to wire inline on the reverse circuit, going to fit it behind the clutch peddle so the reverse button only
works when the clutch is pressed ....
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
