Ferrino
| posted on 5/9/04 at 03:33 PM |
Fuel Pump/Regulator?
For carbed BECs, what's the most common setup for fuel pump and regulator?
Is it OK to just use the bike pump with no fuel regulator, or should I stick with my current carbed CEC setup of solid-state-Facet (6-7 PSI, highest
rating) by the tank with Filter King regulator next to the engine?
I should be getting the bike pump with the engine (R1), so have the option of either setup.
Brooky
| posted on 5/9/04 at 04:27 PM |
stick with the bike pump. They have a regulator built in which shuts off the pump when the pressure is reached.
ChrisGamlin
| posted on 5/9/04 at 07:28 PM |
Agreed, solid state pumps plus regulators have been known to strangle fuel flowrate at the low pressures required for bike carbs (~1.5 - 2psi), so
causing fuelling problems when the carbs are drawing lots of fuel.
Ferrino
| posted on 5/9/04 at 09:58 PM |
Thanks guys - that was the answer I was looking for - means I can raise some money from flogging the pump/regulator, and save some weight too!
