GeoffB
| posted on 6/9/04 at 08:15 PM |
fuel tank return feed.?
i've bought a tank at the donnie show
..ally tank seems really nicely made..does anybody know if running a 97 blade engine with electric pump mean i would/would not have to use the return
feed and if not how do i block it up
Viper
| posted on 6/9/04 at 08:27 PM |
If you don't mind me asking, how much did you pay for the tank?
GeoffB
| posted on 6/9/04 at 08:42 PM |
£95..not sure if its a good price but it was there i needed one and took it to work and showed the welders who were impressed with the quality.
Mikey G
| posted on 6/9/04 at 08:52 PM |
As the blade engine is carbed you do not need a return to tank. if the tank is fitted with a breather just block it off with a bit of old pipe and a
bolt
or get a non return (one way valve) and plumb it in as a breather
Mike
Viper
| posted on 6/9/04 at 08:57 PM |
£95 sounds good but £60 sounds better
DaveFJ
| posted on 7/9/04 at 08:15 AM |
Go on then Viper - where did you get your tank ? and is it a good fit in the Avon ?
Dave
timf
| posted on 7/9/04 at 08:22 AM |
dave
vipers tank fits his avon perfectly.
i think he got it out of his garage
he made it from ally
Tim
Viper
| posted on 7/9/04 at 05:18 PM |
MY tank is stainless.
I do a standard tank for book/mk cars in Alli for £60
Can do you an Avon tank as per the tiger book In alli for £60.
Stainless costs a bit more at the moment because the material is currently quite expensive.
Tim
Viper
| posted on 7/9/04 at 05:19 PM |
Standard tank for book chassis
locoboy
| posted on 8/9/04 at 02:24 PM |
Viper,
Is that the same dims as per the book? or is it your own design to fit a standard book chassis?
If its your own design can you give me rough meaqurements so i can check it in my chassis.
colin
Locoboy
Viper
| posted on 8/9/04 at 05:03 PM |
How's this?
locoboy
| posted on 9/9/04 at 09:16 PM |
thanks, i shall get the tape measure out me thinks
Locoboy
