RickRick
| posted on 2/10/12 at 07:13 PM |
R1 5VY Dash connections
Whats required to re connect the stock R1 clocks? I'm currently using a koso dash, but all the talk about diagnostics modes at the like sounds
like a good idea, but not sure how much of a marathon wiring seshion would be involved
adithorp
| posted on 2/10/12 at 07:25 PM |
The dash connects via 2 plugs. If they're still there then it'd just connect. If the the wires have been cut or re-routed to the Koso
dash, it'd be a case of splicing new wires into the ones going to the Koso. Then you could plug in the Yamaha dash as needed, either using the
original plugs or substitute ones.
Do you have the service manual and wiring diagram?
http://jpsc.org.uk/forum/
