Lightning
| posted on 23/10/12 at 08:36 PM |
where to get tacho for bec dash
The tacho I have reads twice the revs due to waste spark. Where can I get a tacho for dash mounting to suit a 4 cylinder bike engine up to say 12000
revs?
daniel mason
| posted on 23/10/12 at 08:40 PM |
what ecu and dash do you have atm
Lightning
| posted on 23/10/12 at 08:45 PM |
stock zzr1200 ecu general flat dash
daniel mason
| posted on 23/10/12 at 08:49 PM |
do you have the full zzr1200 loom?
a set of zzr clocks could be used and you could probably sell your gauges for more than the price of a set.
failing that im sure you could disconnect your tacho feed and fit another.there are a few digitaal tachos on ebay but cant vouch for there quality!
daviep
| posted on 23/10/12 at 09:05 PM |
Which tacho do you have at the moment? I had the same problem with a revotec (caerbont) gave them a buzz and they sorted it out foc.
Davie
Proby
| posted on 23/10/12 at 09:10 PM |
Am I right in thinking your tacho reads up to 12000, but your actual revs read twice what they should, ie read 6000rpm at 3000rpm actual revs?? If
so you should be able to fix it with a few simple diodes. I had a similar problem when my tacho signal packed up from the ecu, so I took a signal
from one of the coil packs.....
Depending on tacho it might be reprogrammable.....
[Edited on 23/10/12 by Proby]
Visit GraphicMonster
Lightning
| posted on 23/10/12 at 09:18 PM |
Dont exactly what it is. It is Kawaski however, not the zzr1200 though. oh and yes it reads 12000 when it actually is doing 6000 revs
[Edited on 23/10/12 by Lightning]
austin man
| posted on 23/10/12 at 09:33 PM |
It can be sorted with Diodes as said previously someone will no doubt be along in a moment to tell you how.
daviep
| posted on 23/10/12 at 11:39 PM |
I'm pretty sure no amount of diodes are going to help, the rev counter needs to see less pulses per revolution not more.
4cl distributor and coil = 2 pulse per revolution
4cyl wasted spark =1 pulse per revolution (same as 2 cylinder engine)
1cyl engine = 0.5 pulse per revolution (1pulse every 2 revs)
So you can see that if you use diodes so that tacho sees 2pulse /rev then it will over read by 4x, or that's what I see, but I'm not very
sober
I would guess if it's a new ish tacho it was probably run from the ecu and not the coil.
I would recomend CAI (caerbont) purely on the good service I recieved.
Davie
40inches
| posted on 24/10/12 at 07:19 AM |
I used an Acewell, easily adjusted.
matt_gsxr
| posted on 24/10/12 at 11:13 AM |
Aprilia rs125 rev counter is red-lined at 11kRPM but reads to 14k.
(it is 2 cyl, 2 stroke, so expects 1 spark per revolution)
This works fine on my wasted spark gsxr1100 and reads the correct RPM.
You can pick up a rev counter on e-bay for £15 and there are loads out there, black background, white needle, around 2003 model.
Matt
Lightning
| posted on 24/10/12 at 08:03 PM |
Thanks guys very helpful. I'll look on the bay
