Author: Subject: r1 fuel pump connector
chicade
posted on 9/1/13 at 04:37 PM Reply With Quote
hi guys the fuel pump in the r1 powered mk indy has the original bike pump in a sump located in the bottom of the tank the feed connector is horizontal but the return pipe is verticaly sticking out the base of the pump with the fuel hose connected and a loop of pipe to bring the hose horizontal it hangs down is it possible to fit a fitting the same as the fuel feed and if so how any ideas please
renetom
posted on 9/1/13 at 06:01 PM Reply With Quote
pump
Hi
We have an Indy R1 , its a carbed version & we used a ZX9R pump
ZX9R Pump
ZX9R Pump
Works fine.
Good luck
bigfoot4616
posted on 9/1/13 at 06:20 PM Reply With Quote
that pump wont work for injection though.
i found a 90 fuel hose fitting meant the pipe didn't hang quite as low. i would still like to improve it if its possible.
