Author: Subject: 07-08 R1 exhaust manifold dimensions?
jelly head
posted on 18/1/13 at 11:05 AM Reply With Quote
Would anyone on here know the dimensions of a 07-08 R1 exhaust manifold (primary & secondary pipe – lengths and diameters)?
I’ve searched the web and drawn a blank, just wondered if someone on here might have them.
If not I’ll just have to hit ebay and see if I can pick one to have a measure.
Rich.
matt_gsxr
posted on 18/1/13 at 11:38 AM Reply With Quote
If no-one comes up trump then why not go to a local 2nd hand bike dealer and measure?
They will be quiet at this time of year and are normally friendly folk.
TimC
posted on 18/1/13 at 11:40 AM Reply With Quote
When I next get out to the workshop (snow!) I'll have a look - I've got one there I think still, albeit its damaged.
jelly head
posted on 18/1/13 at 01:21 PM Reply With Quote
Blimey, super fast replys!!
That's great - that would be appreciated.
I had thought about that but i wasnt sure if i'd be able to measure the secondary pipe dimensions properly on a bike as in pictures I’ve seen it appears to be a single pipe divided into two and i wasnt sure if i'd be able to determine how far the divider runs… if all that makes sense?
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 18/1/13 at 02:25 PM Reply With Quote
If not, post the question here : http://www.r1-forum.com/
If you can't post let me know and I'll do it for you.
MK9R
posted on 18/1/13 at 02:27 PM Reply With Quote
From what has happened to these engines racing, it seems that you need larger bore than standard to ensure the engine doesn't destroy itself
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
TimC
posted on 18/1/13 at 04:32 PM Reply With Quote
Is that right? Must catch up with Mr Rickers!
MK9R
posted on 18/1/13 at 05:01 PM Reply With Quote
Speak to andy grant, his engine was reliable after he had a Tony law system built, I'd say Tony is the man to build you what you need
Cheers Austen
RGB car number 9
www.trackace.co.uk
TimC
posted on 18/1/13 at 06:38 PM Reply With Quote
Its a lot easier for me to see Charlie at Pro Speed who built Bob's...
MK9R
posted on 18/1/13 at 06:42 PM Reply With Quote
I know its a long way but I am well happy with the Tony law system I have, good prices too
Cheers Austen
RGB car number 9
www.trackace.co.uk
jelly head
posted on 19/1/13 at 08:44 AM Reply With Quote
Hmmm having the engine stay together would be nice... so avoid the standard manifold dimensions then, any ideas how much larger?
Tony law is fairly local for me so a visit would be easy enough, do you think he'd know what would work best with this engine?
MK9R
posted on 19/1/13 at 09:53 AM Reply With Quote
If Tony if local he's your man. Only thing is he only works in mild steel, doesn't make stainless. I'll ask the guy from rgb what the dims are
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 19/1/13 at 07:25 PM Reply With Quote
Andy's manifold is 40mm outside dia, so think its 38mm internal as mild steel
Cheers Austen
RGB car number 9
www.trackace.co.uk
jelly head
posted on 20/1/13 at 10:37 AM Reply With Quote
Thanks for the replies.
Rich
