Neadles
| posted on 31/1/13 at 03:54 PM |
Digi Dash and Gear Indicator
Ok I'm after a little advice if anyone has a similar setup. I have a Digi dash with the speed trigger input for the magnet and sensor setup at
the prop shaft. My question is I want to put a separate digital gear indicator above the steering wheel, but obviously require a speed input, now can
the signal cable be broken into and the speed signal piggy-backed onto before I go cutting away?
Thanks all!
Chris
loggyboy
| posted on 31/1/13 at 04:09 PM |
I cant see why not, however electrical gremlins can crop up anywhere.
If you patch it in carefully and it did cause issues it wouldnt be hard to remove the split and add a seperate magnet/sensor dedicated to the gear
read out.
Mistral Motorsport
rb968
| posted on 31/1/13 at 04:33 PM |
I did that on mine and had no issues.
Rich
Neadles
| posted on 31/1/13 at 06:18 PM |
Rich
What make is yours Rich?
I spoke to ETB and they said there speed sensor is a NPN circuit and if the other is not the same it can just ground out the signal and thus loosing
the signal to the Digi Dash.
rb968
| posted on 31/1/13 at 10:15 PM |
Sorry mine is a Koso rx1n dash and Acumen dg8 gear indicator.
I spliced into the rev and speedo feed on my zx9.
May not help ou with our ETB Digidash sorry.
Rich
