chrisf
| posted on 27/9/04 at 05:29 PM |
Fireblade Engine slant/depth
I'm ready to instal my Blade motor in my locost chassis. The output for the propshaft wants to hit the chassis rail (entry to the trans tunnel).
To correct this, I slanted the motor a bit. It now runs parallel to the upper chassis rail and about an inch away from it. This allows a bit more
space for the prop (when it comes). Does this seem reasonable? It seems a bit strange that the engine does not sit parallel to the trans tunnel...
I checked the HellFire site but could not tell from the pics what they did.
Also, I have the motor positioned 1 inch below the chassis (standard sump). This still seems a bit high. Is this about what you locost blade owners
run?
Any help is appreciated.
[Edited on 27/9/04 by chrisf]
Jon Ison
| posted on 27/9/04 at 05:58 PM |
Cant remember how far below the chassis rail i had the sump but i too ran my engine parallel to the top chassis rail with less than 1"
clearence, worked fine for me.
Lightning
| posted on 27/9/04 at 06:20 PM |
Thats about where mine is. But get the sump plug moved to the side.
I promise you you will knock it off and loose all your oil.
I know , I was that man!
chrisf
| posted on 28/9/04 at 12:57 PM |
Thanks for the help. I now have the engine in position and ready for the motor mounts.
I suppose you are right about the drain bolt sitcking down. This is certainly something I need to fix before the first drive!
--Chris
