Author: Subject: Fireblade clocks or my acewell
Nurburg2006
posted on 23/5/13 at 10:54 PM Reply With Quote
Hi guys, I've just removed my old xflow and just starting to put my blade engine in not sure what dash to use so do I buy a fireblade clock or stick with my acewell? Also I've had to remove a support bar on the near side to fit the cradle any pictures of what you have done wold be great. Cheers
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 24/5/13 at 07:01 AM Reply With Quote
I had a similar dilemma as you and the only justification for going down the bike clocks route in my R1 was so I could use the engine diagnostics if I ever needed it.
jossey
posted on 24/5/13 at 07:55 AM Reply With Quote
Go with ye current ace well. Most do.
I'm just working on the cradle this weekend on my fireblade engine. Mine is a tiger though
David Johnson
watsonpj
posted on 24/5/13 at 08:23 AM Reply With Quote
I've had the fireblade clocks for a while and I'm thinking of changing to the acewell to tomake the dash look better so I say stick with it.
regards Pete
