Nurburg2006
| posted on 3/6/13 at 03:05 PM |
Prop to engine sprocket bolt size
Hello guys I am after the size of bolts for the sprocket I was told it was m8x12.9x30 but they are much to small, not sure what make sprocket it is
tho. Many thanks chris
twybrow
| posted on 3/6/13 at 03:23 PM |
Too small as in too short? Or too small as in length? The two prop adaptors I have had have both needed M8 (12.9 grade), but different lengths due to
different designs. Can you not measure it?
Nurburg2006
| posted on 3/6/13 at 03:33 PM |
I will measure it later the bolt needs to be something like m10 cheers.
