T66
| posted on 22/6/13 at 07:36 PM |
Pingel Shifter
I have a Pingel shifter, which I would like to move from its present location, back through the bulkhead line into the cab area behind/between the
seats.
Reason for this was made after I made the exhaust manifold, and its proximity to the gear cable, and because of a few lame excuses. I still need to
spend some time playing with the lever lengths, intention is to cut down the gearbox lever a bit further.
Anyway - dont want a manual gear cable, so Im going for buttons on the wheel and no manual back up.
Will it be reasonable to fabricate a pushrod to fit the end of the Pingel and mount it further away from the gear lever ?
designer
| posted on 22/6/13 at 07:42 PM |
There should be no problem, but how far?
If it was too far I would support the pushrod with a bush half way along.
T66
| posted on 22/6/13 at 07:44 PM |
I had in mind about 30-35cm and supporting the extension with a small rose joint at a suitable point. ?
The vertical square tube to the right of the white plug, is the bulkhead line, so thats the distance, just enough to move the solenoid away from the
heat.
[Edited on 22/6/13 by T66]
imp paul
| posted on 23/6/13 at 08:33 AM |
it should work fine ivo nice bit of kit mate ,hope its going to plan pal
T66
| posted on 23/6/13 at 10:44 AM |
What plan ?
