ian.stewart
| posted on 24/6/13 at 07:47 PM |
Bike gearchange
Still brainstorming this project, gear changing has been on my mind, bell cranks and rose joints is obviously what a few of you use, has anybody got
success with using a single cable, possibly something like a auto box shifter cable which allow push and pull actions, something like this--
http://bmracing.com/?wpsc-product=super-duty-race-shifter-cables-3ft-super-duty-cable-eyeletthread-ends
ReMan
| posted on 24/6/13 at 08:27 PM |
Push pull cable is the way to go
varios threads, on this but defo easiest option and smooooth
http://www.locostbuilders.co.uk/viewthread.php?tid=172948
www.plusnine.co.uk
Duncan36
| posted on 24/6/13 at 08:30 PM |
Mine is a 6mm Teflon lined cable. It had a 5mm one in before but it snapped after few race weekends and test days. Mine came from my cars
manufacturer, Paul at Spire Sports Cars. I believe he can have them done to any size
www.acorn-printing.co.uk
www.tshirtuk.com
ian.stewart
| posted on 24/6/13 at 09:03 PM |
mmm, Im liking this site, People seem to think along the same lines as I do.
My thoughts on steering wheel wont allow me to use a paddle, so Im going to use a lever in the normal position, my Idea was to mount the lever thru a
cortina void bush and use the bush as the pivot with the void front and back, so I have a self centering lever that has a ease of movement going front
to back, then fit the cable to the underside of the lever coming out of the bush, that way, on the prototype I can alter the shift ratio to suit my
feel.
ReMan
| posted on 24/6/13 at 09:22 PM |
feel.
Easy. any bush will do, as long as you dont add friction or tight bends the lever will still self centre with the gearbox springingness
www.plusnine.co.uk
ReMan
| posted on 24/6/13 at 09:23 PM |
ONLY LIKING IT/
You'll soon love/live it
www.plusnine.co.uk
MK9R
| posted on 24/6/13 at 10:11 PM |
I used an auto box cable on mine, works a treat and more substantial than a lot of the specialist ones
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
T66
| posted on 24/6/13 at 10:48 PM |
Measure up and try ARD, my custom cable came in at £40.
http://www.ardracecars.com/
james h
| posted on 24/6/13 at 10:55 PM |
Cable is a good option. Make sure you can fix a strong bracket at each end of it though, as any flexing will make the change feel less direct.
For my car, I've gone down the route of rods and levers. I couldn't get large radii on my cable, and there was a bit of stiction as a
result. Using rod ends in my setup brings friction to a minimum and changing gear (although isn't moving yet this summer!) is as direct as I can
get it. I was finding false neutral a lot last time the car was on the road, due to a lot of slop in the gearchange mechanism.
I'll post a photo when I've reassembled everything, it might give you some inspiration!
p.s. I've gone for paddleshift but the theory is the same if you want to use a gear lever with rods etc.
James
