Proby
| posted on 30/6/13 at 04:28 PM |
New clutch in! Run out and an oil leak. :-(
Well, after having a few bits missing last week and putting it off, but finally got around to an oil/filter change and the new clutch. While the
sump was empty, I decided to change the gear change shaft oil seal as it was weeping a little. All seemed to go well.
Got it all back together, filled her with fresh oil. Started it up. Moved it using the clutch a few feet and all seemed great. Topped the oil up
(to make up for the oil filter volume), donned my driving shoes and off I went. All seemed fine lines, oil pressure good, clutch good. Yipeeeeee!
Got home and pulled on the drive. Popped bonnet and had a quick check around for leaks and it's leaking from the new gear change shaft oil
seal. Gggrrrrrrr. Looks like it's back on the axle stands in the week.
Rant over!!
Visit GraphicMonster
