Jon Ison
| posted on 6/7/13 at 07:09 PM |
I'm ok with spanners but electrics ?
Hayabusa regulator, gen one single plug.
The plugs a bit fried, so is it ok to do away with the plug and just solder the joints ? I'm guessing its fried due to corrosion/ill fitting
over time as outputs are all as they should be ?
Secondly, would it be an improvement to rune the -ve side back to the negative on the battery, it currently disappears into the loom ?
mark chandler
| posted on 6/7/13 at 07:20 PM |
Yes, common fault.
Jon Ison
| posted on 6/7/13 at 07:41 PM |
Think I will pull all the wires out the loom and check there length, they have been hot.
