mark chandler
posted on 6/9/13 at 11:17 AM |
Budget electric reverse
I,m starting a new topic on my budget electric reverse.
Costs so far are £61, I will need to add a switch and some wire to connect it all but so am hopeful to get away with £70 in total.
The plan is to fit a cog to the outside of the lobro joint on my sierra diff, solidly mount a winch motor above this and run a spur gear to connect
everything up.
Parts purchased then are basic 250 kg winch, eBay £30
Myford gears from RDGtools
- lobro joint 1x95 tooth
- Winch 1 x 72 tooth
- Spur gear 1 x 22 tooth
As this proceeds I will post updates, it will be a little heavier than other people's ones due to the weight of the winch 4.8kg so all up
6kg.
It should work out at around 2 - 3mph if my maths work out and be powerful enough to pull up slopes with ease.
Regards Mark
[Edited on 6/9/13 by mark chandler]
minitici
posted on 6/9/13 at 03:09 PM |
typeR
Yes good powerful motors - made a few myself.
