MarkClow
| posted on 19/10/04 at 07:05 PM |
Fuel pump & regulator for GSXR1000
Hi
I am building a GSXR1000 car and I have noticed that the stock GSXR pump probably wont work as it was designed to run inside the tank.
Are there any other bike pumps / fuel regulators I could use? Do you know if the injected CBR fuel pump would work?
Thanks alot,
Mark
OX
| posted on 19/10/04 at 08:54 PM |
my busa pump was the same,so martin made me a swirl pot about 2 inches deep and i attached the pump to that ,the problem then is that the bottom of
the fuel pump is about 4 inches below the bottom of the tank so i had to raise the tank up as far as it would go
MarkClow
| posted on 20/10/04 at 01:02 PM |
Thats a good idea ... I might do the same.
Are you using a pump between the main tank and the swirl pot or is it underneath fed by gravity? o you think you can post some piccys of it up next
time you update your site?
Thanks very much for the reply!
[Edited on 20/10/04 by MarkClow]
