adithorp
| posted on 2/11/13 at 11:41 AM |
BUSA oil temp position?
I've got a BUSA engined car in work. The oil temp' sender is T'd into the end of the pipe to the remote oil presure sensor.
Obviously there's no flow through this blind pipe (fine for pressure reading) so the gauge doesn't reflect the actual oil temp'.
Where's the best place to fit the sender?
The other end of the existing pipe is into the rear of the block oil gallery where the flexi pipe comes up to the head. Thats isn't an option as
it's tight for space/accessbbut I suppose the other end is. Is there a better position somewhere else on the engine or in the SBD dry
sump/system?
http://jpsc.org.uk/forum/
daniel mason
| posted on 2/11/13 at 11:57 AM |
my caterham busa oil temp sensor was in the dry sump tank. but i didnt think this was the best solution either
Jon Ison
| posted on 2/11/13 at 01:29 PM |
I have mine in the sump.
adithorp
| posted on 2/11/13 at 07:02 PM |
Don't suppose you've got a picture of where? Does it give a decent reading?
GreigM
| posted on 2/11/13 at 10:05 PM |
Bottom of the dry sump tank is the usual place - that way you are reading the temperature just before it goes into the engine.
iiyama
| posted on 9/11/13 at 08:15 PM |
Mines fitted in a sandwich plate by the oil filter.
Those with dry sumps, can you give an indication of oil temps that your getting?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
GreigM
| posted on 9/11/13 at 08:40 PM |
On a recent wet/cool day at Oulton where I'm not pushing particularly hard it was sitting around the 80C mark - looks like the oil and water
temps are pretty similar, which I suppose makes sense.
iiyama
| posted on 9/11/13 at 09:40 PM |
Interesting, what size cooler have you got fitted?
And edited to ask where the temp sender is fitted!
[Edited on 9/11/13 by iiyama]
GreigM
| posted on 9/11/13 at 09:59 PM |
I've got a fairly large cooler which I arrived at by trial and error - had water temp problems and figured the oil was overheating and boiling
the water, so by cooling the oil I got the water temps under control. The cooler is a 25-row (the original westfield one was 19-row).
Temp sender fitted at bottom of oil tank.
iiyama
| posted on 10/11/13 at 07:43 PM |
Ah, ok. Not a fair comparison then as I have the sender fitted a the oil filter.
Couldn't get temps up, (regardless of ambient temps), so reduced the size of the cooler from a 16 row at 405mm wide to a 10 row of the same
width. No change at all in temps. So Ive removed the cooler completely and have now seen temps of over 109. Before they wouldn't go above 65-70.
Oil tank is middle sized Pace tank so I carry around 6.5L of oil. Have also tried a an oil stat with the smaller cooler, no change!
Not overly happy with the temps as they are so need to put a cooler back in but don't want to keep throwing cash at the problem like it's
going out of fashion!!
Sorry OP, sort of hijacked, (hopefully useful information though!!)
Ciavatta
| posted on 22/11/13 at 03:36 PM |
quote: Originally posted by iiyama Have also tried a an oil stat with the smaller cooler, no change!
That sounds pretty strange!
What's your oil routing?
iiyama
| posted on 22/11/13 at 09:19 PM |
Sump-scavenge pump-oil stat, (when fitted),-cooler, (when fitted),-oil tank
adithorp
| posted on 22/11/13 at 09:59 PM |
As the tank wasn't really an option and after a bit of research, I've fitted the temp sender to spare plug on the scavenge pump, where
there's a choice of two possible outlet pipe positions. Drilled and tapped the original plug.
