cerbera
| posted on 29/10/04 at 02:42 AM |
Oil Pressure Gauge
I want to fit an oil pressure gauge and after looking at whats available, I can get either a mechanical or electrical one. Can either be fitted to my
ZX9R C2? If so, which is the best to fit?
MK9R
| posted on 2/11/04 at 07:42 AM |
If you go electric, you could either replace the standard pressure switch or run a T piece from this orifice and run both standard switch and oil
pressure sended. If you replace the switch with a sender unit do not screw the sender directly into the block as the extra weight of the sender will
strip/crack the thread in the block. Mount the sender o the chassis and connect it using a piece of high pressure pipe
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Ferrino
| posted on 17/11/04 at 11:46 AM |
Guys, I need to buy a VDO oil pressure sensor for my R1 and there are a few flavours with different ranges - is 0-5 BAR the one most commonly used on
BECs? This was what I used with the car engine, but my engine manual only gives oil pressure @ idle.
