Author: Subject: L.S.D.
sting
posted on 3/10/02 at 09:28 AM Reply With Quote
L.S.D.
Hi Guys
Me again!
which ratio lsd is best 3.62 or 3.9 for bec with zx9 engine and 13" rims.i`m a little confused with all this ratio stuff
any advice greatly recieved
cheers
Sting
ChrisGamlin
posted on 3/10/02 at 04:14 PM Reply With Quote
With 13" rims, you'll probably want the highest rear diff available, especially as a ZX9 has quite low overall gearing. Don't forget that highest geared = lowest number, so a 3.6 is higher geared (so higher top speed but slightly slower acceleration) than a 3.9, so I'd go for a 3.54 which is the highest you'll get for an Escort live axle.
Chris
sting
posted on 4/10/02 at 09:14 AM Reply With Quote
Thanks Chris
Top man i appreciate the advice
Regards
Sting
Adrian Elkin
posted on 5/10/02 at 04:35 PM Reply With Quote
Sting,
I'm assuming from the ratios your quoting that you're using a Sierra diff. I've done a bit of homework over the past few weeks on gearing as I too have a ZX9C2 engine, but I'm stuck with an Timken (English) diff in which 3.54 is the tallest ratio I can find. But ideally you & I ideally need a Sierra 3.14:1.
Drop me your email address and I'll send you copies of the graphs I've done, etc.
Regards
Adrian
sting
posted on 7/10/02 at 10:22 AM Reply With Quote
Hi Adrian E-mail on its way.
Sting
Adrian Elkin
posted on 7/10/02 at 01:56 PM Reply With Quote
Sting,
Got your message. Hope what I've sent makes sense. Get in touch if you have any problems.
All the Best
Adrian
sting
posted on 7/10/02 at 03:26 PM Reply With Quote
Yup,
It does make sense.
Seems great just need to find a diff!
Sting
JoaoCaldeira
posted on 4/11/02 at 02:29 PM Reply With Quote
Hi!
Was there any Sierra with 3.14 diff? Which one?
Joćo Caldeira
