Flick
posted on 12/2/14 at 01:58 AM |
hayabusa pair valve
hi
have a hayabusa gen1 which still has pair valve fitted. A small vacuum that runs off the top of it, where does it go?
cosmick
posted on 12/2/14 at 09:00 AM |
It is fed from one of the vacuum take offs on the throttle bodies. There are 2 take offs per cylinder use just one, anyone. The other take offs should
all join together and go to the MAP sensor.
If it can't be fixed with a hammer then its probably an electrical problem.
Flick
posted on 14/2/14 at 02:01 PM |
Thanks mate, its been cut short so wasn't sure. Think its time I invested in a manual!
