markmcc21
| posted on 21/2/14 at 11:30 AM |
Fuel warning light on ZX10r clock.
Hi all, filled up the tank on car and separate fuel gauge is working however on the bike speedo its reading fuel warning and the amber lights
flashing. The clock is off a 2007 zx10r. Previous owner mentioned he had the problem in the past which was an earth fault on the fuel tank, had it
fixed but its obviously come back. The battery has just been disconnected and changed so maybe this could be something to do with it? Has anyone had
this before? same cause or different? is it something I can just live with?
Cheers for any advice guys.
Regards.
[Edited on 21/2/14 by markmcc21]
Davey D
| posted on 21/2/14 at 12:02 PM |
If you are just going to use your separate fuel gauge, then you should be able to just connect your fuel warning light for the clocks to your chassis
to turn the light off... you will just have to trace the wire from your standard clocks to see where it goes to. does it use the original zx10 fuel
pump/fuel level sensor?
markmcc21
| posted on 21/2/14 at 03:36 PM |
Thanks Davey ill get a good look at it over the wkend. Im not sure if its using the bikes fuel pump/sensors or aftermarket as I havnt had a chance to
get a good look under the bonnet. Only bought it yesterday and she went straight into the garage when i got home as it was dark. But routing that wire
seems like a good start.
zx12r dug
| posted on 21/2/14 at 09:02 PM |
Fuel light
Hi i had trouble with the light flashing on my R1 clocks couldnt find out what was wrong and ended up using a separate gauge took the clocks apart and
blanked the display off a little crude i know but i couldnt see i flashing at me no more
[Edited on 21/2/14 by zx12r dug]
markmcc21
| posted on 21/2/14 at 09:45 PM |
I think this is the route I'm going to take. I'm just fortunate to have a separate fuel gauge.
