Author: Subject: Nova flange coupling and bailey Morris TRT prop
timbo7
posted on 1/3/14 at 07:09 PM Reply With Quote
I ran a TRT BM prop on my last Westfield hayabusa.
I am now building again and need a little advise.
I was planning to use both the BM TRT prop with centre bearing and the NOVA flange coupling on the gearbox output shaft. For reverse system I am looking at the Lynx starter motor set up. Question - if I fit the Nova coupling will this prevent fitting the reverse gear cog driven off the starter pinion to the Nova coupling. By using the Nova coupling will the reverse have to driven off the diff flange side?
WESTFIELD HAYABUSA 1400 - SOLD
phelix
posted on 27/4/14 at 01:42 PM Reply With Quote
Did you ever get an answer to this query?
timbo7
posted on 27/4/14 at 07:34 PM Reply With Quote
Not yet mate.
Kit arriving shortly so will be getting to the detail of this later
Minicooper
posted on 28/4/14 at 11:35 AM Reply With Quote
You won't be able to use the nova coupling/propshaft with the Lynx AE electric reverse
You'll need to use the propshaft type electric reverse, I see that Lynx now do a propshaft style electric reverse so that may do the job
[Edited on 28/4/14 by Minicooper]
