teegray19
| posted on 9/3/14 at 09:04 PM |
Bike fuel pumps??
teegray19
| posted on 9/3/14 at 09:06 PM |
Bloody iPhones!
Anyways what I ment to post....
Will a standard bike pump, pump from the tank to the carbs? I've seen a lot of people gravity feed the pump up into the engine bay?
| posted on 9/3/14 at 09:15 PM |
What you looking for?
Bike pumps are OK down under the tank gravity filling.
That whatnot after?
whitestu
| posted on 9/3/14 at 09:22 PM |
A bike pump will work if installed in the engine bay but will have an easier life if gravity fed under the tank.
dave_424
| posted on 9/3/14 at 10:03 PM |
I thought I saw on here that bike pumps work better in the engine bay with a long draw length from the tank, or that they like that situation better
teegray19
| posted on 9/3/14 at 10:39 PM |
I've put in a bike engine over the winter and I've currently got the set up with the fuel pump just under the tank.
I've seen a lot of installs with the pump right next to carbs in the engine bay, guess il just give it a blast and see what happens unless
someone on here tells me otherwise!
cheers for the responses,
| posted on 9/3/14 at 11:10 PM |
Do you need a intank pump?
renetom
| posted on 10/3/14 at 07:28 AM |
pump
Hi
On our R1 we have a ZX9R pump under the tank, copper pipe to
the front with flex each end & it works great.
Good luck
René
  ZX9R Pump
jossey
| posted on 10/3/14 at 08:16 AM |
In the engine will work ok when the fuel eventually gets to the pump. Drawing it through won't be easy. On the zzr I had it took ages to draw
the fuel up and did not sound happy pumping air through. Also cained my battery a lot which I was surprised with.
David Johnson
matt_gsxr
| posted on 10/3/14 at 09:51 AM |
Pump under tank works well.
The pumps don't suck air very well.
