Jodieshann
posted on 18/3/14 at 10:41 AM |
90 Degree Exhaust Tip
Hi guys,
Has anyone got an idea where i can get a 90 degree tip to fit on the end of my R1 can from? I believe it's a 2" diamenter. It's
currently got a 45 degree fitted and it's blowing on the rear arch and melting my arch protector. Ideally with a rolled end, but without will
also work.
Weldable with an arc welder would be handy too.
40inches
posted on 18/3/14 at 10:55 AM |
I used one of these 90 degree Mandrel Bend Stainless Steel 50mm 2 inch
I just pushed it in with RTV exhaust sealant, and held it in with a screw from the back.
1800 miles later and it's still there and doesn't leak
Jodieshann
posted on 18/3/14 at 11:42 AM |
excellent - thanks for the tip. I'll give that a go.
mark chandler
posted on 18/3/14 at 12:39 PM |
You can weld early R1cans, later ones are titanium so you will struggle. The push and screw is starting to look favourite.
These are very restrictive cans BTW
40inches
posted on 18/3/14 at 01:52 PM |
My can is Titanium, hence the screw fixing. That bend is ,I think, expensive but I couldn't find a tight mandrel bent one any cheaper
SPYDER
posted on 18/3/14 at 02:46 PM |
I bought a second can to give me two hangers and two front end caps. I removed the rear angled end cap by drilling out the rivets and also removed the
inner end cap. This is titanium but behind this the internals were steel. I cut off the 45 degree steel stub and replaced it with a large diameter 45
degree bend that I had slash cut. I then slid a front cap over it and riveted it on.
You could do the same with a 90 bend.
