ianminki
| posted on 10/4/14 at 05:01 PM |
radiator fan switch
hi all
looking for some help with regards to my stylus which has a fireblade 893 engine I have just replaced the radiator and fan as it was in need of
a new one .the problem I now have is the fan will not kick in once engine is up to temp. the only difference is that the fan switch is no long in the
rad. Should I put it in the top hose or the bottom . any diagrams would be of help. all parts are new including the fan switch
regards ian
| posted on 10/4/14 at 06:46 PM |
Put it in the top hose but you probably find it cuts too early as this is the hottest part of the system, the work around. Is to use a switch that
cuts in and out at a slightly higher temperature than the previous switch.
ianminki
| posted on 12/4/14 at 08:11 AM |
rad fan switch
hi
thanks for that .got that done but still having problems looks like im now having water flow problems as i'm unable to get rid of air lock or
there is a blockage some where waterpump looks ok so not sure what to do now any help pls would be grate thanks
regards ian
