Matt21
posted on 15/4/14 at 01:37 PM |
CBR900 Loosing oil
Hi all,
Since winter my MK seems to be using oil.
There are no signs of leaks, theres no smoke from the exhaust, theres a bit of residue from the breather on the rocker cover (I havnt looked in the
catch tank but theres no signs of oil on the level indicator on the side).
I had to add a litre of oil the other day after around 150miles of driving, surely that much oil loss would be visable?!
engine is a 98 cbr900
any ideas where to start?!
OliilO
posted on 15/4/14 at 02:06 PM |
Probably a stupid question, but was it at the correct level before you went out? Possible that there was some residue on the sight glass making it
look fuller than it was?
Matt21
posted on 15/4/14 at 02:52 PM |
I have serviced it over winter, new oil and filter
added the right amount of oil and had it sat between the 2 lines etc
noticed it looked empty the other day so added some oil, then ~150miles later noticed it was low again.
this second time I gave the sight glass a wipe down to make sure it was all clean, iv not been out in it since and im away at work now so cant do a
'test run'
OliilO
posted on 25/4/14 at 09:41 PM |
Bizarrely, I now seem to have a similar disappearance of oil. Posted in the engines section as well, i want to find where the oil has gone now!
