chrisf
| posted on 12/11/04 at 06:54 PM |
Blade clutch pedal spring?
My clutch cable is a standard Westfield unit. I have it connected to my Blade motor and can disengage/engage the clutch. However, when I disengage the
clutch, the inner cable does not allow the ctuch to return to the engaged position. The cable is not connected to the pedal--I'm pulling it with
my hand.
I've looked through many build site and it does not appear as though the other builders are using a secondary spring to pull return the clutch
Does this seem right? Does anyone have any suggestions?
--Chris
Jasper
| posted on 12/11/04 at 09:41 PM |
I used the clutch return spling on the pedal as well.
chrisf
| posted on 12/11/04 at 09:44 PM |
Jasper:
Do you have any pics?
--Thanks, Chris
ChrisGamlin
| posted on 13/11/04 at 11:22 PM |
It doesnt sound right if you can pull the clutch cable with just your hand, are you sure you're not just taking up the slack when doing that?
The clutch lever should end up pointing towards the general direction of the oil filter when the clutch is disengaged (ie approx
"11-o-clock" when looking at the engine from the gearbox side), and its not something you can usually do with your hand without a lever to
assist.
Chris
[Edited on 13/11/04 by ChrisGamlin]
chrisf
| posted on 14/11/04 at 05:04 AM |
Yes, the clutch disengages exactly as you describe. I can do this by pulling on the cable. In fact, I can disengage the clutch just using my hand
(cable removed).
The clutch lever has a spring on it--it is just weak. I assumed that it was standard because the rider would use his hand. Should the spring on the
clutch lever (on the gearbox) be increadibly stiff where it would be difficult to pull with my hand? Perhaps mine is broken. I'll have another
look, but any other suggestions??
OK, just had a look. Seems like the spring is standard Honda affair. Do any blade owners have a close up picture of their clutch lever assembly? Seems
everyone leaves these off the build sites.
--Thanks, Chris
[Edited on 14/11/04 by chrisf]
