Author: Subject: Clutch arm
greavesy7
posted on 2/12/14 at 10:44 PM Reply With Quote
Clutch arm
Currently doing a Bec conversion and while fitting the clutch cable I acidently pulled out the cluch arm. I've put it back in but I can't remember how much movement I should have ? It's a zx9r f engine
dave_424
posted on 2/12/14 at 11:45 PM Reply With Quote
Whenever I have had mine out, i just slipped it back in with a wiggle and a twist, usually it inserts when rotated anticlockwise about 1/4 turn from where it sits at norman operation. Only ever had it go back in the correct way.
greavesy7
posted on 2/12/14 at 11:48 PM Reply With Quote
So it's normal for it to come out
dave_424
posted on 3/12/14 at 12:03 AM Reply With Quote
Yes it is designed to be able to be pulled out pretty easily, but in normal clutch operation it shouldn't be coming out
