cloudy
| posted on 17/3/15 at 10:40 PM |
Turbo BEC - Intercooler?
Building a medium boost GSXR1000 - aiming for 230hp , how critical is intercooling the intake charge going to be do you think?
Thanks,
James
www.warnercars.com
bi22le
| posted on 17/3/15 at 11:38 PM |
Very.
Read on here using the search and people have seen 15bhp gains by dropping the inlet temp by only a few degrees.
Please read my ring story:
dave_424
| posted on 18/3/15 at 12:25 AM |
What is the configuration of your engine/turbo system? If you are using standard internals and running close to the limit then I would say
intercooling is essential
cloudy
| posted on 18/3/15 at 08:21 AM |
That's cleared that up then! Standard internals (HG spacer) with a TD04
James
www.warnercars.com
mark chandler
| posted on 18/3/15 at 11:53 AM |
My blade runs standard compression, 7 psi boost and a decent intercooler with optimax. 135bhp >>> 201bhp
Although bikes have high compression ratio's they are all designed to run on 93ron, adding a plate is not required with mild boost, just better
fuel and a cool charge.
Build without, if it pinks add the plate.
[Edited on 18/3/15 by mark chandler]
dave_424
| posted on 18/3/15 at 12:32 PM |
Mine ZX9 ran standard internals and compression, 7psi with megasquirt, 97 octane fuel for safety and intercooled. 125bhp to 181bhp with the smallest
TD04
cloudy
| posted on 18/3/15 at 01:21 PM |
Great info - seen a lot of people saying now that standard compression is probably fine - saves pulling the head...
James
www.warnercars.com
dave_424
| posted on 18/3/15 at 01:34 PM |
Just make sure you can adjust ignition timing vs boost, running boosted on standard ignition advance isn't wise
cloudy
| posted on 18/3/15 at 03:03 PM |
Was planning to use a Power commander 5 - they do an ignition module, reckon timing is going to need to be adjusted at boost for this power level?
[Edited on 18/3/15 by cloudy]
www.warnercars.com
dave_424
| posted on 18/3/15 at 03:06 PM |
I know some people get away with it, but I personally wouldn't on a road car.
