jlayton
| posted on 9/5/15 at 08:30 PM |
R1 water flow
Hi, in desperate need to know what way the water flows on the r1 5pw. It's to plumb the water lines up for my turbo
Thanks in adavance
CosKev3
| posted on 9/5/15 at 09:20 PM |
On which part of the system?
jlayton
| posted on 9/5/15 at 09:28 PM |
Just need to know if the water pumps up through the engine,then to top of rad. Or does it flow from the bottom of the rad to the top.
Hope that makes sense
CosKev3
| posted on 9/5/15 at 09:44 PM |
Thermostat is in the pipe going to rad, so that's the hot water exiting the engine.
kentmagpie
| posted on 10/5/15 at 07:03 PM |
I'm not 100% sure on an r1 but most engines will rely on the thermostat to build heat up in the engine and then at optimum temperature release
out. Most commonly higher up the engine flowing to the top of the rad and down through out the bottom and back round again. On car engines most water
pumps are bolted on the side of the head pumping water through the engine. On my last bec I had an external electronic water pump that seriously
worked at a rate of knots but effectively still doing the same job as a car setup. Sorry if sounds confusin but hope this helps
gabbes
| posted on 29/8/15 at 05:09 AM |
The waterflow is from the lowest point - bottom and upwards. Download the service manual for the motorcycle and you will have a wonderful description
there with photos.
