carpmart
| posted on 17/6/15 at 07:55 AM |
ZZR1100, any difference between c and d
chaps
Do the c and d variants have the same engine mounting points as each other? Actually, more specifically, do I have to be careful to buy a specific
model to match the one I blew up in my Radical the other day, or do they all fit th same?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
minitici
| posted on 17/6/15 at 08:24 AM |
The output sprockets are different - one has a dish and the other is flat.
Can't remember which was which but I think the 'C' was dished.
The flat sprockets are easier to find in different sizes.
Other than that the two units should bolt-in just the same.
minitici
| posted on 17/6/15 at 08:31 AM |
One other thing to consider is to fit the extra cam cover drain, that Radical fitted, to your new engine.
The ZZR1100 tends to keep too much oil at the top of the engine which leads to oil starvation and subsequent bearing failure with the inevitable
ventilated crankcase!
carpmart
| posted on 17/6/15 at 09:18 AM |
Yep, I'm guessing that is exactly what has happened, hole in block... Not happy....
Thanks for the info...
Just on the sprockets, do they end up in the same plane, so I won't need to re align to get the chain straight?
Do you know f there would be any reason to think that the dry sump system will not be interchangeable too?
[Edited on 17/6/15 by carpmart]
'94 MX5 MK1, 1.8
minitici
| posted on 17/6/15 at 10:53 AM |
I think the two sprockets would end up in the same plane when used on their respective engines.
They are just not interchangeable with each other.
Have you got the Muzzys type dry sump? (uses original ZZR oil pump)
carpmart
| posted on 17/6/15 at 11:18 AM |
Thanks for the confirmation on the sprockets...
I'm afraid I'm not sure what dry sump system is fitted. Do you believe sumps are interchangeable? Assuming they are, then the dry sump
should be OK to interchange too.
As for the gears, I can easily get whatever sprocket I want made up by the excellent JB Gears in N Yorkshire.....
'94 MX5 MK1, 1.8
teegray19
| posted on 17/6/15 at 11:15 PM |
Sumps, engine mounts headers etc all the same.
Output shaft is not, the c is 30mm shorter than the d model. This caught me out and I had to make a spacer.
It's not a dishes sprocket - the output shaft its self is shorter
Built Formular 27 with 1600cc crossflow, 1700cc 0 miles crossflow, Kawasaki ZZR1100
