craig5
| posted on 23/6/15 at 01:19 PM |
speed sensor on 5vy
anyone know where it is within my loom as what to connect a gear indicator
CosKev3
| posted on 23/6/15 at 01:52 PM |
Sensor itself is on the side of gearbox, near your brake master cylinder.
Pretty close together will be neutral switch which has one wire going to it, and speed sensor which has three wires.
craig5
| posted on 23/6/15 at 01:56 PM |
It's plug I'm after as demon tweeks do a plug and play gipro
CosKev3
| posted on 23/6/15 at 02:00 PM |
Find the sensor and the plug is a few inches from it, could be anywhere in a kit car depending where builder has run loom.
craig5
| posted on 23/6/15 at 02:16 PM |
There are litterly wires and plugs everywhere engine was fitted by Aries but was 2 years ago
CosKev3
| posted on 23/6/15 at 02:45 PM |
If you locate the sensor the plug is only a few inches back up the wiring
craig5
| posted on 23/6/15 at 02:52 PM |
not got clue what sensor looks like
CosKev3
| posted on 23/6/15 at 05:06 PM |
top switch with one wire is neutral switch, lower one is speed sensor and triangular wiring plug is speed sensor plug.
not 100% sure 5vy will be identical to my 5jj but won't be much different.
craig5
| posted on 24/6/15 at 09:33 AM |
think ive found it was other side that was confusing me as theres not 1 wire theres 2
CosKev3
| posted on 24/6/15 at 09:52 AM |
Other side of what?
Its got to be in gearbox, think your looking at wrong sensor if only got two wires.
Don't think you've read what I said correctly, I said neutral indicator has one wire, speed sensor has three.
craig5
| posted on 24/6/15 at 09:59 AM |
3 wires on 1 side and 2 on other
CosKev3
| posted on 24/6/15 at 10:03 AM |
5 wires?
http://www.promasydb.nl/pics/boonstra/000000074825-1.jpg
craig5
| posted on 24/6/15 at 10:05 AM |
3 on that side and 2 on other side of white connector
CosKev3
| posted on 24/6/15 at 10:10 AM |
That's been altered then, should be three on both plugs
craig5
| posted on 24/6/15 at 10:18 AM |
[IMG]http://i1259.photobucket.com/albums/ii554/trueblueeverton/photo56.j
pg[/IMG]
that deffo the sensor?
CosKev3
| posted on 24/6/15 at 12:07 PM |
Yeah
craig5
| posted on 24/6/15 at 12:13 PM |
[IMG]http://i1259.photobucket.com/albums/ii554/trueblueeverton/photo57.j
pg[/IMG]
3 core on 1 side and 2 on other and no signs of mods
