Lightning
posted on 6/12/04 at 05:12 PM |
Battery Isolator
I have fiited a battery isolator. in line with the negative(earth) lead. Yes it cuts the battery, but the car will still run if disconnected via the
generator. The question is how can I make it cut out the engine? For motorsport does it have to do so? I have the bike kill switch would that do?
Ok that was 3 queations
Help required as I would like do hill climbs and the like next year.
Avoneer
posted on 6/12/04 at 05:25 PM |
What's a queation?
I put my isolator on the positive side of the loom and it turns all power off to everything when removed.
Even stops my engine (even though it's a car jobber).
Pat...
Mr G
posted on 6/12/04 at 05:56 PM |
Is it a proper FIA cut off switch (with extra terminals for cutting off extra circuits) or the cheaper ones that will only cut the main in-out to
them?
i.e FIA spec one :
HERE
G
novarallycar
posted on 6/12/04 at 06:00 PM |
it's running on through your alternator charge light believe it or not!! to fix it the isloator should be wired to cut the battery +ve . the
isolator should have four terminals on the back of it and through the n/c contact of these you should wire the ign feed to your coil/ecu . or you can
wire an ign live to the n/o side and from the other side put an 100 ohm resistor to earth.
hth
Lightning
posted on 6/12/04 at 09:31 PM |
AAAAhhhhhh
I knew why it ran on.....its the FIA cut off that will obviously solve the problem.
and Pat don't be a tart, you know what I ment
[Edited on 6/12/04 by Lightning]
scotlad
posted on 6/12/04 at 09:35 PM |
Ive got one o these swithes to fit shortly- guess i'll follow your advice Mr Nova. has it happened to you before or something??
