locost7-online.com
| posted on 15/8/15 at 10:28 AM |
Blade gear linkage rods
I'm just looking at making my gear linkage , what size steel rods should I use and do I use ball joints or rod ends?
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
kj
| posted on 15/8/15 at 11:47 AM |
My first m10 rod sleevd with ball joints then changed to rose joints but cheap ones and gave some slack changes and missing gears.
Going to m8 rods sleeved on paddles with quality rose joints.
I have a cable but my opinion found it easier with rods.
Think about it, think about it again and then do it.
locost7-online.com
| posted on 15/8/15 at 11:52 AM |
I was thinking of using 8mm rods, with threaded ends for Rose joints, m8 threads do you think it will be heavy enough?
kj
| posted on 15/8/15 at 04:00 PM |
Sleeving mine with Ali tube to reduce bending under load
kj
adithorp
| posted on 15/8/15 at 05:45 PM |
I tried 8mm ally rod but it had a lot of flex. Then tried steel rod which was better. Finally went with 8mm bore steel tube with studs inserted/welded
and that was stiffer and lighter. Used rod ends on them. Having a left-hand thread on one end of one of the rods makes adjustment easy.
[URL=http://s189.photobucket.com/user/adrianthorp/media/fury069.jpg.html] [/U
RL]
http://jpsc.org.uk/forum/
