Crazy Jay
| posted on 10/12/04 at 04:31 PM |
CBR RAD
Hey, i've picked up a cbr1000 radiator for my R1 engine, jus wondering if any1 has done this before and have pics?
Also is it ok to mount the rad inside the frame in the "Crumple zone" space in front of engine??
Thanx
| posted on 10/12/04 at 04:48 PM |
As you are building it, it is your choice believe it or not
As the Rad will restrict flow of air... the air will choose the path of least resistance, which would be where you don't want it, down the
sides. Can't see it having much difference though... apart from adjusting stuff and possibly getting to the clutch? It's just much simpler
at the front of the frame. the room inside the frame is pretty small and restricted.
Just a thought...
HTH
[Edited on 10-12-04 by Hellfire]
Crazy Jay
| posted on 10/12/04 at 04:51 PM |
Ahh cheers. Will prob just stick it on the front then. Hows ur car goin?? Can i remember u sayin ur gettin a new engine or did i make tht up??
scotlad
| posted on 10/12/04 at 05:18 PM |
or was that me??? fairly sure my mk radiator set up holds around 4.5 litres
[Edited on 10/12/04 by scotlad]
| posted on 10/12/04 at 07:37 PM |
I'd thought of doing similar to cut down pipe runs probably using something to duct air to the radiator from the front.
| posted on 10/12/04 at 10:56 PM |
I think it was you Graham... our engine has been sorted for a while.
