Author: Subject: Fuel Pump
welderman
posted on 13/12/04 at 12:27 AM Reply With Quote
Fuel Pump
Would you use the original blade fuel pump or an aftermarket one?.
If aftermarket which one.
posted on 13/12/04 at 12:33 AM Reply With Quote
original due to pressure sensing device.
ReMan
posted on 13/12/04 at 09:42 AM Reply With Quote
Beings as it was yesterdays job I have to strongly advise using the original `Blade pump, and filter, and mounts, and pipes, and clips, and bolts Rescued attachment 1111.jpg
welderman
posted on 14/12/04 at 01:00 AM Reply With Quote
Thanking you ever so kindly. Ta.
Hellfire, do you have pictures in your excelling build diary?.
[Edited on 14/12/04 by welderman]
welderman
posted on 16/12/04 at 11:19 PM Reply With Quote
Whats the pressure sensing device look like?
