Westy325
| posted on 11/11/16 at 11:12 AM |
Westfield Megablade TB-bonnet clearance issues
I'm nearing the end of my megablade ZZR1400 conversation, and I'm having clearance problems between the V8 bonnet and air filter. I reckon
I need 50-75mm more height on the scoop to give sufficient clearance in order to eradicate fretting and restrict airflow. I don't want to simply
cut a hole in the bonnet, I'd ideally like to keep it looking as close to standard looking as possible. Has anyone came across the same issue,
or know of any way which I can extend the bonnet without it looking like something out of mad max.
CosKev3
| posted on 11/11/16 at 03:43 PM |
If you look through Roscos haynes build on here he made up a new bracket to repostion the top set of injectors,then used a open foam filter.
mark chandler
| posted on 11/11/16 at 06:26 PM |
My bonnet was flat, injectors running upside down stubby manifold with maybe 20 degree bend in it.
Westy325
| posted on 11/11/16 at 09:06 PM |
Do you have any pics?
mark chandler
| posted on 11/11/16 at 09:28 PM |
In my archive
  plenum 1
Westy325
| posted on 11/11/16 at 10:40 PM |
Not sure how that would effect performance (torque etc) with NA??
mark chandler
| posted on 11/11/16 at 11:16 PM |
I,m sure you could do something neater, my tb's are mismatched to the engine.
I expect you will lose less than a strangling airbox .
