Banana
| posted on 13/4/17 at 09:17 PM |
Carb question - what is this for
I noticed the diaphragm seems to be pinched on one of my carbs around the area highlighted in the picture.
What does that hole/jet do?
r1_pete
| posted on 13/4/17 at 10:15 PM |
Long time since I worked with cvks but Im sure its the vacuum port which raises the diaphragm / throttle slide.
dd1972
| posted on 14/4/17 at 07:03 AM |
Spot on as this man says.
| posted on 14/4/17 at 08:23 AM |
Yes a depression port it has the same purpose as the holes in an SU or Zenith-Stromberg CD piston.
Banana
| posted on 14/4/17 at 08:38 AM |
Thanks guys, the Haynes book doesn't actually make any reference to it.
Im hoping that is the cause of the hesitancy at full throttle im getting..
r1_pete
| posted on 14/4/17 at 11:03 AM |
If there is any leak around the diaphragm seal you will get poor running, I used to put a layer of ruberlube in the recesses where the bead seats,
keeps the rubber supple, and has a slight swelling property, so ensures a good seal, and makes future removal easier.
