jimmyjonga
posted on 8/1/05 at 02:46 PM |
thanks to chris' uncle
got my sump back from chris gamlin's uncle after he had chopped it for me...
very pleased and would recommend his services to anyone else - good price as well..
james
chunkielad
posted on 8/1/05 at 03:07 PM |
How much does he charge?
jimmyjonga
posted on 8/1/05 at 03:27 PM |
it was 50.00 and 7.50 for postage, very good job too - also modified the oil pick up pipe
james
ChrisGamlin
posted on 8/1/05 at 05:22 PM |
Cheers James, glad you're satisfied
chunkielad, if you look at Jasper's pics below you can see what James had done
Chopped XR9R sump 1
Chopped XR9R sump 1
He also does blade sump plug mods to gain around 15mm for £25 (not nearly as much work)
cheers
Chris
[Edited on 8/1/05 by ChrisGamlin]
shortie
posted on 8/1/05 at 05:44 PM |
He did my blade sump too, top job.
chunkielad
posted on 8/1/05 at 07:54 PM |
Looks like nice work - hasn't it made the sump smaller overall though? Don't you have to add a bit on the side (excuse me I'm new to
this)?
When I get to this stage I think I'll give him a shout!!!
ChrisGamlin
posted on 9/1/05 at 08:47 PM |
It does reduce the capacity a little yes, but if you look at the amount chopped off its probably less than 300ml so not a lot really considering the
engine holds 4L or so. As long as you fill to the same level (ie reduce the amount you put in and don't overfill) then Ive not heard of any
problems, this is exactly how Z-Cars etc used to mod the ZX9 sumps too.
Chris
[Edited on 9/1/05 by ChrisGamlin]
