mi2jaca
| posted on 15/10/17 at 05:54 PM |
Single seater track day tool
Made of wood on a strict budget using a smaller than “usual” motorcycle engine.
I am taking a little different approach to the locost concept although I am not sure if this qualifies as a locost. Thought I would share this
anyways. Comments and critique is welcome but try to be nice, I understand that I am out of the normal locost “box” but please don’t be nasty to
me.
The idea being to create a very simple to make/build design with relatively cheap components. Monocoque chassi using plywood as primary material with
glued joints keeping everything together. Independent double wishbone front suspension and stiff rear axle with swingarm. Engine from a large single
cylinder four stroke (+600 cc KTM or similar) or maybe a 650 twin (ER6 or similar), not sure yet.
Rear axle, wheels and tires from a Superkart should cope with the performance I am aiming for but at the same time keep costs down? Am I right?
Still only in the basic design stages so please bear with me and be gentle
//C
JAG
| posted on 15/10/17 at 06:26 PM |
Sounds like a great idea - if you only want a track day car
Have you thought about how you'll attach the metal wishbones to the wooden monocoque chassis?
Are you using bushes or Rose type joints?
How will you bolt to the wooden monocoque?
Plenty of high performance craft are made/were made from Plywood.
Always loved the De Havilland Mosquito - and that's all Plywood airframe
Justin
perksy
| posted on 15/10/17 at 06:28 PM |
Are many single seater track days available in the UK ?
CosKev3
| posted on 15/10/17 at 06:37 PM |
As above,not many single seater track days.
Lots of test days for competition cars,but I wouldn't mind betting something made of wood wouldn't be allowed on?
ettore bugatti
| posted on 15/10/17 at 07:03 PM |
I like the concept.
I assume you already have seen the Hyper Pro Racer?
Nickp
| posted on 15/10/17 at 07:07 PM |
You may get on with some wheel arches / cycle wings, but tbh would you want to be sharing a track with potential loons in 2ton tin tops?? Ermm, not me
Dingz
| posted on 15/10/17 at 10:50 PM |
" I wouldn't mind betting something made of wood wouldn't be allowed on "
That would rule out early Marcos cars, and Costin Amigos, for a start.
The Costin raced at LeMans.
[Edited on 15/10/17 by Dingz]
went on and on.
mi2jaca
| posted on 16/10/17 at 06:30 AM |
The part about actually getting this thing on the track could be a show stopper. Will maybe talk about it with some organizers and I have a friend
running a Radical who maybe has some connections I can use. Was hoping that the novelty of the design would open a few doors. I am also a little
uncertain about what lap times to expect, I don’t want to big differences if i mix it up with other cars. The more I think about it the worse it
sound.
Of course I am inspired by the Hyper Pro Racer but that’s on the other side of the world and costs a small fortune. Being a family man means that I am
on a low budget but I try not to look at the total cost to much but instead to make an annual budget that decides my spending’s and my rate of
progress year by year. As an engineer I am of course using an Excel-sheet to keep track.
Since I lack any form of real fabrication skills or facility’s I plan on using as much of external manufacturing resources as possible and keeping my
focus on a simple to assemble design. I am a mechanical engineer by trade so I have some feel for what works and what doesn’t. So far I have ordered
and received some samples for laser cut plywood parts to evaluate and test. Attachment to the wooden monocoque is still being debated.
Has anyone used www.weerg.com to make metal parts? They do look interesting since I have no problem designing parts in 3D CAD.
//C
[Edited on 16/10/17 by mi2jaca]
Sam_68
| posted on 16/10/17 at 07:51 AM |
Regrettably, I think you might find that the opposite is true: both track day organisers and track operators are increasingly cautious in these
litigious times, and will be happier with something that is either road legal, or is MSA scrutineered within a recognised race class.
I assume that you're already fully conversant with Frank Costin's work, but if the plywood construction is a major objective for you and
you'd be willing to consider something a little more conventional as the path of least resistance for track use, then this project might
interest you by way of inspiration:
The Logan Superior
Camber Dave
| posted on 16/10/17 at 09:22 AM |
I spent far too much time trying to build a ‘two seater’ racing sports car using Carbon fibre honeycomb flat panels.
The main problems are.
• Wasted space at the intersections of the panels/buklheads
• Load paths of suspension and major components
• Routing and securing of pipes and cables through the monocoque
The result was a mess of an oversize main tub, a space frame for engine/rear suspension and an overweight alloy box for the front suspension, pedals,
brakes and inboard coilovers.
If I was to do it again, I would forget the chassis initially.
Draw/3d model the driver, power unit cooling system, box and drive train, fuel tank etc as close as possible to each other.
Work out the weight distribution of this package. Then model the layout of your suspension and dampers.
You will then find that flat panels are unlikely to ‘join up the dots’.
However plywood (or Carbon/honeycomb) bulkheads could be used. The essential chassis/monocoque will be multi-planed to keep overall dimensions small
and the load paths can be be fed into junctions of panels/buklheads.
Like the Lotus Elite, Marcos and Costin decades ago, GRP can be used. But like the Lotus Elan construction is eased by having a ‘chassis’, in reality
a load spreading component. The torsional rigidity was substantially increased by the body shell.
Sam_68
| posted on 16/10/17 at 09:57 AM |
I saw the photos of your tub when you put it up for sale, so I understand what you're saying.
I've been through the same process, and initially ran up against the same problems as you - your bullet points are all horribly familiar, and a
few others besides!
With a lot of thought (quite a bit of it lateral!) I've come up with solutions that I'm happy with to all the critical issues, however
(indeed it ultimately resolved itself into a ridiculously simple and efficient design): it can be done, I reckon - but it's taken
me several years of thinking and playing around with models and test sections to get there!
The OP's design is obviously preliminary, but it incorporates some very valid features - in particular the horizontal elements at cockpit top
and mid-height level, which will substantially stiffen the cockpit opening. If I remember correctly, your design was very similar to the Strathcarron
tub for the cockpit area - basically just an open top box with no returns or perimeter stiffening around the upper edge of the side panels - so would
have been lacking stiffness in that area.
[Edited on 16/10/17 by Sam_68]
Camber Dave
| posted on 16/10/17 at 10:13 AM |
Quote
If I remember correctly, your design was very similar to the Strathcarron tub for the cockpit area - basically just an open top box with no returns or
perimeter stiffening around the upper edge of the side panels - so would have been lacking stiffness in that area.
Agreed
My customer had the design FEA'd and was happy. However I was intending to add outward horizontal flanges 'to support the
bodyshell'.
As you say the project was offered for over a year but unsalable. I now have £15k of carbon honeycomb to dispose of, offers anyone?
Sam_68
| posted on 16/10/17 at 03:24 PM |
Purely out of curiosity, do you recall what sort of figures it was generating for torsional stiffness?
Camber Dave
| posted on 16/10/17 at 04:20 PM |
Sorry Sam not disclosed to me, though I often wondered.
U2U sent
steve m
| posted on 16/10/17 at 04:27 PM |
I had thought of doing something similar about 15 years ago, as build with wood !
But my way of doing this was to make a ladder section in 100mm steel square, (still have some in the garage)
The metal chassis would of been for all the suspension to hang/suspend from, and to locate the engine on
But the rest of the car would of been in marine ply, my aim was for a 60's lemans lola, style
somewhere, I have the folder with all my musings, and if I had a double garage, it would off been started
steve
ettore bugatti
| posted on 16/10/17 at 06:33 PM |
I just remembered, Motus build some gokarts with a plywood chassis/ monocoque.
I think they were even used in sprint and or hillclimbs
